Sachtler Ace XL Mark II Fluid Head $499 (Reg $719)
2 Min Read
Sachtler Ace XL Mark II Fluid Head (75mm Bowl)
B&H Photo has the higher-end and highly-rated Sachtler Ace XL Mark II Fluid Head (75mm Bowl) in their DealZone for $499 today. That is a savings of $220 off the regular price.
Key Features:
The Sachtler Ace XL Mark II Fluid Head is designed to facilitate smooth pan and tilt movements with your cine-style camera configurations thanks to its 17.6 lb load capacity. The fluid head can be secured to 75mm bowl mount tripods.
Sachtler Ace XL Mark II OVERVIEW
The Sachtler Ace XL Mark II Fluid Head is designed to facilitate smooth pan and tilt movements with your cine-style camera configurations thanks to its 17.6 lb load capacity. The fluid head can be secured to 75mm bowl mount tripods. It has 9 + 0 steps of counterbalance and 3 + 0 steps of pan/tilt drag adjustment. A total tilt range of +90° to -75° allows for intuitive framing of your shots.
Mount your camera using the slide-in balancing plate with a 1/4″-20 screw and locating pin. With a sliding range of 4.1″, this head can adapt to any rig configuration. Additional features include a detachable pan bar and an illuminated bubble level. An integrated flat head base allows the Ace XL Mark II to be mounted onto a slider.
SOURCES:B&H Photo
