B&H Photo has the Sachtler Flowtech 75 MS Carbon Fiber Tripod System with Ace XL Mark II Fluid Head kit in their DealZone for $1599 (Reg $2299) today. This is a terrific deal on this high end tripod/head combo.
Purchase Options
Overview
- Ace XL Mark II Fluid Head
- Flowtech 75 Carbon Fiber Tripod
- 17.6 lb Load Capacity
- 9-Step + 0 Counterbalance
- 3-Step + 0 Pan/Tilt Drag
- Mid-Level Spreader
Sachtler Ace XL Mark II Fluid Head (75mm Bowl)
The Sachtler Ace XL Mark II Fluid Head is designed to facilitate smooth pan and tilt movements with your cine-style camera configurations thanks to its 17.6 lb load capacity. The fluid head can be secured to 75mm bowl mount tripods.
It has 9 + 0 steps of counterbalance and 3 + 0 steps of pan/tilt drag adjustment. A total tilt range of +90° to -75° allows for intuitive framing of your shots.
Mount your camera using the slide-in balancing plate with a 1/4″-20 screw and locating pin. With a sliding range of 4.1″, this head can adapt to any rig configuration. Additional features include a detachable pan bar and an illuminated bubble level.
An integrated flat head base allows the Ace XL Mark II to be mounted onto a slider.
Sachtler Flowtech 75 MS Carbon Fiber Tripod with Mid-Level Spreader and Rubber Feet
The Sachtler Flowtech 75 MS Carbon Fiber Tripod with Mid-Level Spreader and Rubber Feet eschews the common single or double carbon fiber tube design and instead has redesigned the shape of the legs for improved torsional strength.
The legs work weigh just under 7 pounds yet they can support a payload of up to 44 pounds, and extend from a minimum height of 24″ to a maximum height of 61″ when using the included removable mid-level spreader. Each leg features a single clamping lever that locks and unlocks the sections.
Each leg extends or retracts independently from the other two, and when it is detached from the spreader each leg can pivot without affecting the other legs. This is especially useful when working on rough or uneven terrain.
You can remove the spreader completely and lock each leg in one of three positions, so you can work without a spreader if you wish. This enables you to spread the legs extremely wide for low shots, while the tripod legs maintain their torsional stability.
The dual spikes at the end of each leg provide extra grip when working on softer ground, and you can snap rubber feet onto the dual spikes for better grip when working on hard or delicate surfaces.
