SIGMA launches interchangeable lenses for Nikon Z Mount system
2 Min Read
SIGMA Corporation (CEO: Kazuto Yamaki) is pleased to announce the upcoming launch of interchangeable lenses for Nikon Z Mount system. This addition allows users to enjoy high performance, and high quality SIGMA lenses in native mount on their Z Mount system. Three F1.4 prime lenses (16mm F1.4 DC DN | Contemporary, 30mm F1.4 DC DN | Contemporary, 56mm F1.4 DC DN | Contemporary), which are currently available in five mounts (Sony E-mount, Canon EF-M mount, FUJIFILM X Mount, Micro Four Thirds mount and L-Mount) will be simultaneously released in Z Mount.
Lineup
  • SIGMA 16mm F1.4 DC DN | Contemporary
  • SIGMA 30mm F1.4 DC DN | Contemporary
  • SIGMA 56mm F1.4 DC DN | Contemporary
Main specifications and features
Control algorithm including AF drive and communication speed optimization has been developed specifically for Z Mount interchangeable lenses. In addition to realizing high-speed AF, the lens also supports AF-C (Continuous AF) and in-camera aberration correction*. The mount is rubber-sealed to cater for use in a variety of environments.
* Available on supported cameras only.
Specifications
  • 16mm F1.4 DC DN | Contemporary
    • Lens Construction:16 elements in 13 groups
    • Angle of View:83.2°
    • Number of Diaphragm Blades:9 (Rounded diaphragm)
    • Minimum Aperture:F16
      Minimum Focusing Distance:25cm
    • Maximum Magnification Ratio:1:9.9
    • Filter size:φ67mm
      Dimensions (Diameter × Length):φ72.2mm × 94.3mm
    • Weight:420g
    • Compatible hood:LH716-01
  • 30mm F1.4 DC DN | Contemporary
    • Lens Construction:9 elements in 7 groups
    • Angle of View:50.7°
    • Minimum Focusing Distance:30cm
    • Maximum Magnification Ratio:1:7
    • Filter size:φ52mm
    • Dimensions (Diameter × Length):φ70.0mm × 75.3mm
    • Weight:285g
    • Compatible hood:LH586-01
  • 56mm F1.4 DC DN | Contemporary
    • Lens Construction:10 elements in 6 groups
    • Angle of View:28.5°|Number of Diaphragm Blades:9 (Rounded diaphragm)
    • Minimum Focusing Distance:50cm
    • Maximum Magnification Ratio:1:7.4
    • Filter size:φ55mm
    • Dimensions (Diameter × Length):φ70.0mm × 61.5mm
    • Weight:295g
    • Compatible hood:LH582-01
1 comment
