B&H Photo has the SmallRig AD-Pro8 Professional Fluid Head Tripod Kit in their DealZone today for only $499 (Reg $799). If you're looking for a good value video rig, this SmallRig setup is a good choice.
Purchase Options
Overview
- Professional Tripod 75mm Ball Fluid Head
- Carbon Fiber Tripod Legs
- Manfrotto Snap-In Quick Release Plate
- 22.8 to 77.2″ Height Range
- Ground & Mid-Level Spreaders
- Interchangeable Spiked & Wide Feet
- 360° Panning, +90/-60° Tilting
- 6-Step Counterbalance, 4-Step Drag
- Adjustable Pan Bar, 17.6 lb Maximum Load
- Includes Carry Bag
The AD-Pro8 Professional Fluid Head Tripod Kit from SmallRig is a durable and portable video tripod system for professional photographers, videographers, and vloggers. The system includes the PH8 professional tripod fluid head and heavy-duty carbon fiber tripod legs. A carry bag is included to store and transport the entire system.
The durable fluid head features a Manfrotto 501PL-type quick release plate with a snap-in plate design, a 75mm half ball base that can support up to 17.6 lb, 6-step counterbalance, 4-step pan/tilt drag settings, 360° panning, and +90/-60° tilting.
A telescoping pan handle extends from 13.8 to 20.9″ in length, and it can rotate 360° on the right or left rosette.
The carbon fiber legs feature removable spiked feet, a mid-level spreader, and a ground spreader for added stability options. It allows you to extend your camera rig from 22.8 to 77.2″ in height. It folds down to 38″ in length for transport.
