The SmallRig S 60 2-Person Wireless Microphone System with USB-C Connector for Mobile Devices (2.4 GHz, White) is on for $59.99 (Reg $89.99) today only in the B&H Photo DealZone. If you're looking for an inexepnsive wireless solution, these should be on your shortlist.
SmallRig S 60 Features
- For Content Creation, Vlogging
- 2-Person Shoots with Mobile Devices
- 2 x Transmitters with Built-In Mics
- Dual-Channel USB-C Plug-In Receiver
- 984′ Transmission Distance
- Noise Reduction, 3-Level Gain Control
- Double-Tap Mute Function
- 11-Hour Battery Life, Charging Case
SmallRig S 60 2-Person Wireless Microphone System $59.99 (Reg $89.99)
About the SmallRig S 60
Record two-person vlogs or interviews with your compatible Android or iOS device using the SmallRig S 60 2-Person Wireless Microphone System. The system includes two clip-on transmitters with built-in microphones and a dual-channel, plug-in receiver with a USB-C connector, which inserts into your compatible. Attach the transmitters to your talent using the magnetic back clips, adhesive pads, and adhesive neck strap.
All of the components can communicate from up to 984′ away via 2.4 GHz frequency. An onboard button on the transmitters can toggle noise reduction with a single tap and mute with a double-tap. Controls on the receiver can adjust the 3-levels of gain. The receiver runs on plug-in power from your device and offers a port to charge your connected mobile device simultaneously. A built-in battery in each transmitter powers the unit for up to 11 hours at a time. The included charging case can extend that runtime to 40 hours.
