B&H Photovideo has the SmallRig VB155 155Wh Mini V-Mount Li-Ion Battery on sale for $169.99, saving you $170.00.
Features include
- 155Wh Lithium-Ion V-Mount Battery
- Supports up to 14A Draw
- 1 x 14.8V D-Tap Output
- USB-A Output, 2 x DC Barrel Outputs
- USB-C Input/Output
- D-Tap & USB-C Fast PD Charging
- Ultra-Compact, Travel-Friendly Size
Purchase the SmallRig VB155 155Wh Mini V-Mount Li-Ion Battery on sale for $237.99
The VB155 Mini V-Mount Battery from SmallRig is an ultracompact, lightweight 155Wh battery that can support up to a 14A draw at a nominal 14.8V. This travel-friendly battery is suitable for powering handheld cameras, drones, and gimbals.
The VB155 provides multiple accessory ports, including one 14.8V D-Tap output, one 8 VDC barrel output, one 12 VDC barrel output, one USB-C output, and one USB-A output for powering various accessories, cameras, or mobile devices. The battery can be charged using a standard V-mount charger, an optional D-Tap charger, or by using the USB-C input/output with a 65W PD fast charger. A built-in OLED display shows the remaining battery capacity and status.
