SmallRig VB212 Mini V-Mount Battery $249 (Reg $439)
Richard Cox
2 Min Read
SmallRig x Caleb Pike VB212 Mini V-Mount Battery Header
B&H Photo has the SmallRig x Caleb Pike VB212 Mini V-Mount Battery in their DealZone today for only $249, which is a $190 savings. SmallRig makes some of the most popular V-Mount batteries for your cameras and accessories.
Please note that B&H Photo will be closed today due to the weather in in New York City and will re-open and begin shipping again tomorrow.
$249 $439
The SmallRig x Caleb Pike VB212 Mini V-Mount Battery is an ultracompact, lightweight 212Wh capacity battery that can support up to a 10A draw with a nominal 14.76V output. This travel-friendly battery is suitable for powering handheld cameras, drones, and gimbals.
SmallRig VB212 Mini V-Mount Battery Overview
  • 212Wh Lithium-Ion V-Mount Battery
  • Supports up to 10A Draw
  • 2 x 14.8V D-Tap Outputs
  • USB-C Outputs, 2 x DC Barrel Outputs
  • USB-C Input/Output
  • USB-C Fast PD Charging up to 140W
  • Ultracompact, Travel-Friendly Size
The VB212 provides multiple accessory ports, including one 14.8V D-tap output, one 8 VDC barrel output, one 12 VDC barrel output, one USB-C output, and one USB-A output for powering various accessories, cameras, or mobile devices. The battery can be charged using a standard V-mount charger, an optional D-tap charger, or via the USB-C input/output with a PD fast charger. A built-in bright OLED display shows the remaining battery capacity and status.
Follow:
