SmallRig has the SmallRig x Caleb Pike VB212 mini V Mount Battery at it's lowest price ever. You can save 25% on the batteryy, bringing the price down to $330 (Reg $439).
For Canon shooters, this battery can power your R5C at 4K/60P for up to 11.5 hours with an 18W consumption rate. You can also use this battery to charge things like a Macbook Pro 3 times, or an iPhone more than a dozen times. If you're in need of quick power for your laptop, you can get around a 20% charge on MacBook Pro 16 in about 10 minutes.
SmallRig x Caleb Pike VB212 mini V Mount Battery can also be fully changed in about two hours, which is impressive for a 14.4AH battery.
· Powerful Performance: Boasting a 212W capacity and 140W of PD 3.1.
· Fast Charging: Bi-direction PD Rapid Charging, fully charged in 2 hours.
· Pocket Size: Travel-Friendly Design, highly integrated design.
· Durable Build: featuring a scratch-resistant PC and acrylic front cover.
Simply add the battery to your cart to see the discounted price.
SmallRig x Caleb Pike VB212 mini V Mount Battery $330 (Reg $439)
Specifications
| Items | Specifications | |
| Material(s) | Aluminum Alloy, Silicone, TPU, PC V0 | |
| Capacity | 14.76V 14.4Ah 212.544Wh | |
| Rated Power | Output: 212W Input: 140W | |
| Input | USB-C1 / USB-C2 | 140W (Max.) |
| D-Tap1 | 8A (Max.) | |
| BP | 10A (Max.) | |
| Output | USB-C1 / USB-C2 | 5V / 3A, 9V / 3A, 12V / 3A, 15V / 3A, 20V / 5A, 28V / 5A (Max.) |
| USB-A | 5V / 3A, 9V / 3A, 12V / 2.5A (Max.) | |
| BP | 14.76V / 19A (Max.) | |
| D-Tap1 | 14.76V / 10A (Max.) | |
| D-Tap2 | 14.76V / 6A (Max.) | |
| 8V-OUT | 8V / 3A (Max.) | |
| 12V-OUT | 12V / 3A (Max.) | |
| Charging Protocol | USB-C1 / USB-C2 | PD3.1 / QC2.0 / QC3.0 / PPS / AFC / DCP-1.5A / APPLE-2.4A |
| USB-A | QC2.0 / QC3.0 / AFC/ DCP-1.5A / APPLE-2.4A | |
| Cutoff Voltage | 11.2V | |
| Operating Temperature | -15℃ to 60℃ / 5°F to 140°F | |
| Charging Temperature | 0℃ to 50℃ / 32°F to 122°F | |
| Optional Charging Method | BP port charger, 16.8V D-Tap charger, USB-C charger | |
