SmallRig X-Touch Smart Triple-Proof X99 Battery (99Wh, V-Mount) $199 (Reg $299)
2 Min Read
B&H Photo has the well-regarded SmallRig X-Touch Smart Triple-Proof X99 Battery (99Wh, V-Mount) in their DealZone today for only $199 (Reg $299)
Purchase
  • Smart App Control, 2″ Touchscreen
  • Triple-Proof Durability, IP54 Rated
  • 14.5V | 99Wh | 6800mAh
  • D-Tap, USB-C, USB-A & DC Barrel Ports
  • USB-C 100W Fast Charging
  • 4.9′ Drop-Resistant Housing
  • BMS Control Chip
  • Backlight Indicator, Mounting Threads
The X-Touch Smart Triple-Proof X99 Battery from SmallRig is designed to survive the rigors of set while providing reliable power to a wide variety of devices. This V-mount battery features a 14.5V, 99Wh, 6800mAh rated capacity with strategically placed ports that allow it to power various accessories. The battery's triple-proof design makes it incredibly durable.
An IP54 rating makes it water and dustproof, while the housing is drop-resistant up to 4.9′. A 2″ touchscreen display and dedicated mobile app facilitate smart control over the battery's functions and streamlines status monitoring.
Utilize the two D-Tap, two USB-C, one USB-A, and two DC barrel ports to deliver power and charge multiple devices simultaneously thanks to their independent circuits.
The USB-C ports support 100W fast charging and an integrated BMS control chip allows for rapid charging of the battery in just two hours. Additional 1/4″-20 and 3/8″-16 threads provide flexible mounting options and a backlight indicator helps you secure it even in low lighting conditions.
