1DX - issues in low light at reception / Edit..use expansion pts, problem solved
  • Thread starter Thread starter mjcphoto
  • Start date Start date
Re: 1DX - issues in low light at reception
In low light I definitely never try to spot focus, ever, in any situation. I've found it just doesn't make that much difference in most, not all, but most, situations. I've had fantastic luck with the 5D Mark III in very low light, I just haven't tried the 1DX there yet.
Thanks guys! I just played around with expansion and it seems like it does the trick just fine!
I guess I was so used to single point selection with my previous 1D's (and it worked all the time), that I never went there. I'm also a control freak (I'm sure many others here are as well) and love control of my point. That said, looks like I'll have even more control in using expansion in lower light or backlit situations indoors as well. Thanks so much!
I love that you can pull up a Custom Function within the modes. Dig the fact that it remembers where your focus point was when you go from landscape to portrait...makes formals a breeze! Okay, it is the holy grail!!!
mjcphoto said:
However, I shot a wedding reception in relatively low light this past weekend and I had trouble both acquiring focus at times and with images that were out of focus (after focus had been confirmed).
Hi Michael,
I'm glad you found a solution, I just wanted to make sure that you're aware of the Auto-Focus Micro-Adjustment bug, which occurs when you have your AF point linked to portrait or landscape orientation, and then the AFMA settings for your lens doesn't take affect. Since you said that you locked focus on a few shots and they were still OOF, I just wanted to make sure that you were aware of the bug.
Rich
The AF points are smaller due to their being 61 of them, so using the AF assist points makes a bit of sense. I had trouble with my 5D MK III in low light, that might fix it as well.
Haha it makes me feel good to not be the only one that went through this!
You must have set the 1d X up wrong, because even if you have a magic 7d and 1d3, the X is still way better. But to use that supersmall spot af will be a poor choice for lowlight and without expansion points the iTR tracking doesn't work. I find the 1d X to be without question the best camera on every level ever produced. I shoot in 12800 f1,4 light with 1/80s and the exposure and af works fantastic!
+1
I just had some professional 8 x 10 prints done with metallic luster with a 1DX and they look just as good as any 22mp photos I have taken with the 5D Mark III.
Actually, I set up a custom function group from the start to have the ability to turn and capture something on the fly (love that). And the standard back button focus lock using the asterisk like on all my other 1D bodies. I also set up the focusing points to just show the points that work best with F2.8 lenses and wider. So it's pretty dialed in.
I suppose I was just used to my 1D MKIII working in 1 point spot mode in extremely low light and nailing it. I reckon, going to a full frame makes things a bit difference since the sensor is much larger. The expansion points make a whole lot of sense now. Especially after playing around with it last night recreating the circumstances I was faced with at the wedding. Looks like it also helps having expansion on when shooting into extreme backlit situations. This camera totally rocks!
Thanks again everyone! I'm digging the forum even more than the camera :)
Yeah, just when you thought you knew it all...there is always something more to learn. thanks again!!!!!!
Spot focus never gets turned on unless i can't get something to work with fine details else the contrast area is too small to sample for the focus system to be used regularly. Single point Af is the standard i have used for years. Canon needs contrast for focus and you decrease it in spot focus mode but like an eye or a diamond or shooting through branches or something it is necessary to have that smaller sampling area so the camera doesn't lock on to the wrong subject. Maybe the fact that the contrast area has motion at really slow shutter speeds leaving it confused a bit but then the flash beam assist should solve that one. I rarely use 1/15 sec for anything unless i want ot create an effect anyway. There is a point where ambient and flash are competing and you will get oof if the shutter speed is too slow but then when its night you can freeze almost anything with flash. Its not good to gamble below 1/40th or 1/60 when balancing out the light, at least that is what i find. I haven't experimented with expanding focus points but for sports and i found the 4 pt expansion to be the best for my results.
I guess I meant to say, single point mode (not spot). Single point works great in low like on the 1D Mark III, but I've now learned that the 1DX needs expansion points to assist. So far in tests it seems to work.
Regarding shutter speed during a reception with lighting (canon flash is fill on hot shoe/ quantum is triggered remotely as main light). If there are windows in the room and the sun has set (it's dark outside), I'm almost always at 1/25-1/15 shutter so long as I'm not detecting any light on the floor within the meter. This way you control what freezes with the flash, aside from when the subject head is in front of wall light or something similar. You end up not having to kick the ISO up so much and the images look nice and sharp. Also fun to drag the shutter at 1/15 for creating nice motion by moving the camera and or lens if you're working with a zoom.
Bosman said:
These are very helpful tips on how to use the camera. We should start threads for the 1dx and the 5dm3 sharing tips on what worked best in diff situations. It would just be nice to find things in one place, each camera having its own thread of course.
That's a pretty good idea!!
BTW I would still like to know if anyone knows if dpreview is going to test or have published or when we'll see the results of the 1d X vs the D4. I have always read their tests and I would like to just for fun, although, I must say dpreview have dropped CONSIDERABLY in quality as a page over the last couple of years. USed to be my goto page, but now it seems outdated and boring.
I would also very much appreciate such threads. I´m a non native speaker and a photographic layman, which is that
don´t dare to start one. I´m would certainly follow very closely the 5Dm3.
Done!
1DX http://www.canonrumors.com/forum/index.php?topic=8714.0
5DMIII http://www.canonrumors.com/forum/index.php?topic=8713.0
I am def going to try expansion in receptions. Its just i expect failed images when shooting avail light at Large Apertures, so i shoot 2 or 3 of each situation sometimes.I may try expansion for larger apertures F4-F5.6 as it seems like this makes more sense than using it with dof below F2.8 but again, i will try it. I may do a whole wedding with 4 pt expansion. I just dont care for 8pt, anyone like 8pt?
I like 8pt, it gives me extra security when things go really fast. WAY better than Zone AF for me. And I can place f1,2 focus with obstacles in the way anyway as they just help, not take over. But with slight movement and/or in one direction, 4 works better.
Okay, so I had an opportunity to try out expansion points in a dark reception setting. Before I get into it, let me again say how flawlessly this camera performs outside, and in lower available light settings. The tracking with AI servo is way more accurate than the 1DMK3 and better than the 1DIV. And the low ISO noise I was getting with the 1DIV isn't present (I had to process noise in shots that were spot on exposure wise to begin with shot at ISO320 with the MKIV). Backlit situations outside..no problem for the 1DX.
However, I'm still running into issues on a low lit dance floor where people are moving. My 1DMKII's and IIN's would lock right onto that stuff historically. And my 1DMKIII, it runs circles around the 1DX in THIS department (emphasis on THIS if you didn't catch it).
Maybe this is something that can be addressed with firmware? Perhaps it's a short coming of the sensor? Again, it performs flawlessly in every other department! It's incredible. I just wish it would lock on as quick or even 1/2 as quick as the 1DMK3. There has to be someone else out there who has noticed a lag. I can't be the only one. And believe me, I'm a huge 1DX fanboy!!!
My work around for the next wedding. Use the 1DX all day long up until the dance floor opens up (in dark settings). Then switch to the 1DMK3 so shots are not missed. At this point I'm usually in the 500-640ISO range and the image quality is great (really just comes down to MP's and I'm cool with that, for now).
Thanks for listening,
Michael
