I recently purchased my first and only Canon Supertele the 500mm. I've been using the lens some now and it is time to clean the rear drop in filter. The surface is open to the back and does protect the other back lens elements. However it has been called a gelatin filter. Is it? It looks like very thin and delicate glass. The Canon documentation seems to indicate that it is a UV filter. Is that true or is it just clear. Can I clean it like any other lens glass or do I need a special fine cloth. Can I use liquid lens cleaner on both surfaces.
By the way, it seem to go into the slot either way. By facing the back of the lens, I assume that you want to see the Canon lettering toward you (facing toward the back lens cap). Am I correct? This may make no difference or might make a difference with a polarizer.
This is my first lens with a rear filter. I'd appreciate your help. Bruce
