Macro Extension Tubes: A way to calculate increased magnification with length of extension?
cayenne
Canon Rumors Premium
Mar 28, 2012
2,907
803
Hi all,
Is there a formula to figure out how much an certain sized macro extension tube will increase the magnification of a macro lens given it's tube length?
Let's say I have 2 macro tube extensions:
1. A 36mm tube (empty tube no optics on any of these)
2. A 20mm tube
Let's say I'm gong to use this with my Canon 100L macro which is 1:1 magnification.
So, if I add the the 36mm, to it...will that increase the magnification of the 100L? If so, is there a way to figure how much increase from 1:! when adding x millimeters of tube?
What would 20 be? What would stacking 36 and 20 give to the 100L's normal 1:1?
Thank you in advance!!!
Cayenne
Try Here:
The information for many lenses is in the lens information charts at TDP.
for example:
100-400mm II
Also, I've run my own tests on several lenses, including zooms at different focal lengths. I used two tubes totaling 32mm and photographed a ruler as close as the lens would focus. In Photoshop, I went to Image Size, turned off resampling, and set the picture width to 36mm, as an approximation of the sensor size. That way the ruler tool would give me a readout of the actual size on the sensor (more or less). So if I measured an inch on the ruler and the info panel told me the image was 1.47 inches, I figured that the magnification must be around 1.47x. That is the result I got with the 16-35mm lens at 35mm with 32mm in tubes. With the non-L 24-105mm lens and 32mm tube length, I got 1:1 for 32mm focal length, and 0.53x for 105mm.
I think some of my results with the 24mm TS-E and my 100mm macro lens are posted in a couple other threads. The extension tubes were delivered the day before I had to send the 24mm back, so I wanted to try some things with it, mainly to use the tilt for depth of field. I recall getting 2x with the macro lens and some tubes, but I don't recall the tube length I used. My notes are somewhere around here.
