Problem with AF with R5 and EF 500mm f4 mk1 and converters...
hello every body,
after a few issue with my R5 and 500mm f4 mk1, with AF, everything went perfectly in order,
no more issue, even with EF 1.4x converter.
I use official RF-EF converter.
firmware is the last.
I recently bought Canon EF converter x2, tried it with 500mm and R5 with no problem, even tried 2x + 1.4x converters, no problem, AF worked.
I switched lens and came back to 500mm with converters and... no AF at all (servo or one shot), mount the 500mm with no converters and ... no AF, tried 500mm +1.4x, no AF.
switched back to RF lens, AF is perfect, swithed to another EF lens (sigma 105mm 1.4 art) and no problem with AF.
But still, no AF with 500mm f4.
i reset the R5, nothing change, reinstall firmware, nothing change.
what's the problem here?
thank you for your help.
yes ;) , first thing i've checked.
try with or without stabilization (who knows?), different AF distance on the lens, every AF setting possible on the R5, no AF.
I've cleaned the contactor of the lens, nothing change.
what's really struggling me is that i've test the 500mm f4 + EF x1.4 + EF x2 +EF/RF +R5 and AF was preatty good.
i've to test the lens on EF camera.
30,931
12,625
Indeed, it is possible (and I'm sorry to suggest it) that the AF on the lens failed.
The only known incompatibility of the MkI IS 'great whites' (200/2, 300/2.8, 400/2.8, 500/4, 600/4, 800/5.6 and 400/4 DO) on an R-series body is that the AF Stop buttons don't work via the adapter (source).
33
10
I've tested it once again on the R5, i did not do any change and... AF is back, well at least till 10-12m , it's perfect but if i aim to a futher subject, AF is heratic again, and do not spot on the subject. Subject is for a while in AF but it constantly jump.
I switch several time from "4m to infinity" , to "10m to infinity", nothing change.
may be this is a "lazy" lens?
Bonjour j'ai également le problème de l'AF qui bloque avec mon 500 mm canon f4.
C'est très frustrant de voir l'oiseau flou sur la branche et ne pas pouvoir obtenir la netteté.
Je suis équipé du r6 et d’autres photographes équipés du r5 ont les mêmes soucis !!! Pouvez-vous me donner la marche à suivre pour régler mon problème ? Merci à tous et à bientôt vous lire…..
glad to see this AF problem on R5 + 500mm f4, is known by others, i was beginning to think my lens was faulty.
but sad for the owners too, because it's very frustrating...
