SIGMA again announces EF-M lenses, and mount conversion service
OneSnark
Canon Fanboy
Aug 20, 2019
62
36
I have, perhaps, a dumb question.
While I am enthused about sigma producing decent fast primes for the EF-M line. . . .why is NOBODY producing F4 (or heaven forbid F2.8) zooms?
I know I could use EF glass on adapters; but frankly if I was wanted to go the adapter route; I would simply by a full frame RP body.
I would have thought there would have been a natural market for such F4 EF-M lenses.
I know of ONE guy who would pony up. :)
andrei1989
Sep 1, 2014
392
85
33
one guy is not a market
canon keeps constant aperture zooms for their full frame cameras. there was only one exception, the 17-55 2.8
i would like to see some semi pro zooms for the M line too, but i won't hold my breath
Travel_Photographer
Travel, Landscape, Architecture
Aug 30, 2019
94
126
So I'm circling back to this older thread since I just received a rental Sigma 16mm F1.4 today to try on my M6 (along with an RF 35mm F1.8 IS for an RP).
First impressions, it's definitely a quality lens. To cut right to one of the ongoing discussions about lens barrel diameter, I see no particular disadvantage to the wider diameter of this lens compared to the smaller (and identical) diameter of all the current EF-M lenses. If Canon produced wider diameter lenses for EF-M, I'd be fine with that.
That said, while this lens balances "fine" on my M6, it is definitely longer and heavier than I expected. Ergonomically, it doesn't feel quite as part of the camera as the EF-M lenses that I own do (22mm, 32mm, 15-45, and 55-200). Though it obviously wasn't designed specifically for Canon, but rather for Sony and Micro Four Thirds.
I did some indoor and outdoor side-by-side image quality tests with the 15-45mm set at 16mm, and both lenses set at F5.6 (I just picked a generally middle-ground aperture). Maybe the Sigma was a little sharper than the 15-45, but I'd have to really pixel peep at full-size to see it. That was just a preliminary couple of test scenarios, though, around the house, some flowers outdoors, etc. We'll see how it goes for the rest of my time with it.
If you need fast shutter speeds for moving subjects, then I can certainly see the appeal of this lens over the slower 15-45. For non-moving subjects, the image stabilization in the 15-45mm may more than make up the difference for the narrower aperture.
All four of my other EF-M lenses, including the 55-200mm, I would consider "walk around" lenses, meaning I'm happy to hike all day with them. I'm not sure I'd be happy walking around all day with this lens, given its weight and extra bulk. I'll give it a try and see how it feels. For me, being able to walk around all day with an M-series camera is a large part of the appeal. For those that don't prioritize that, the advantage of the faster shutter speeds may make this lens a worthwhile investment. I have it for ten days so we'll see how it goes.
Incidentally, I tried the RF 35mm F1.8 IS on my RP and that lens is *spectacular*. Wow. I've only had that rental one day but I'm definitely buying a new one. The F1.8 aperture combined with the image stabilization is incredible, and the lens is ridiculously sharp.
Photos of the Sigma on my M6:
Compared to the 55-200 (slight distortion in the photo from my cell phone camera):
SteveC
R5
2,577
2,474
That doesn't seem that bad.
I have the Tamron 18-200 made for the M mount, and it too is a bit wider, perhaps more so than this is (it takes a 62mm filter). It certainly doesn't feel like a boat anchor.
Canon *could* bend a little on their diameter fetish, I think, without sacrificing portability (and even if it is sacrificed...it doesn't make the lenses already out there less portable).
Travel_Photographer
Aug 30, 2019
94
126
Agreed. I do like the lens a lot. If I had a need for faster shutter speeds at that focal length, I would definitely be happy snapping one up, knowing that it just wouldn't necessarily be for carting all over town.
I also agree that the more lens options the better. Just because a particular lens may not be the perfect fit for one person, doesn't make it that way for everyone else. Maybe for someone else it's their go-to lens! (y) (y)
