I'd be interested to see if this works with 3rd party cropped body lenses on a M4/3. The Sigma 8-16 (uses the EF mount, even though designed for APS-C bodies) is quite sharp and might be alot of fun. I'm assuming they'd vignette on the NEX.
ok, so in theory you could make one that allows you to use EF lenses on your EF-S camera without losing FoV
but definitely not with this design: this adapter is actually shorter than a dumb glass-less one
I would think* there must be pretty big downsides to having an actually longer adapter (which is what you need for that EF to EF-S thing) while mantaining infinite focus, plus there's a mirror so you can't end up close to the sensor... I'd pretty much rule it out
* that guess is based on the fact that they had no restritions regarding size, and they ended up with a shorter-than-usual adapter: this must be what gives you the best IQ
