Kickstarter: LuminAID Solar Inflatable Lantern and Phone Charger (2-in-1)
1 Min Read
I found this project quite late in the campaign, but for anyone that camps or enjoys outdoor photography, a good light and charging solution is always appreciated.
There are tons of options to back this project, which has already raised over $260,000 of a $15,000 goal.
Product Specifications
  • 2-in-1 solar lantern & phone charger
  • Charges phone at the same speed as a wall outlet! 5V, 2.4Amp USB output port to recharge phones, tablets, cameras.
  • Packs flat to only 1″ thick and inflates into 6″ cube lantern
  • 150 lumen output on Turbo mode
  • 50 hour max run time on Low Mode
  • Two ways to recharge: 1-2 hours by micro USB or 12-14 hours by built-in high efficiency solar panel
  • Use in any weather: it's waterproof, floats, and can be submerged up to 1 meter deep (IP67).
Check out the LuminAID Solar Inflatable Lantern at Kickstarter
Leave a Comment
Leave a Reply
