5D Mark III Firmware Update 1.2.1 Battery Fault
Hi, after I upgraded my 5D mkiii to 1.2.1 my camera does not recognise my batteries which are original canon batteries. I even bought new ones just to be sure. I am certain it happened straight after the update and can find no cure at the moment except canon asking me to return the camera to them for repair. I know the update is supposed to do this for 3rd party batteries but not original canon batteries.. Has anyone come across this ? Cheers....
R1-7D
Jun 25, 2012
726
62
It is a known problem. I have three genuine Canon batteries and my 5D3 only recognizes one as authentic.
fugu82
Mar 3, 2012
200
Bummer. Hope Canon makes it right.
My 5D3 running 1.2.1 even recognizes the Wasabi batteries I stuff into it.
Yes , the camera still works but I get the "batteries not recognised " and press ok.. The batteries are not seen and indicates low battery all the time. Annoying really so I carry spare batteries just in case as I can't see battery levels. I do a lot of field work and it is just another thing to worry about on location. Here's hoping canon will recognise the problem or admit there is a problem. If they did at least I would know they are working on it. Just wanted to advise not to upgrade if you haven't already and wait for the next one.. :) Hope a fix comes soon..
15,940
1,056
The fix is to send in your defective camera. This is not a normal occurrence, I've had two 5D MK III's and no issues like that. Canon did apparently update some of their batteries about the first of the year.
Don't expect a firmware fix, it will likely never come.
cliffwang
Feb 7, 2012
501
Morgan Hill, CA
I guess firmware 1.2.1 might do checksum based on both camera information and battery information. Unfortunately the new algorithm has a flaw, so it doesn't work well with your camera. It shouldn't affect any function of this camera. I think Canon should fix the problem in the next firmware. You should report the issue to Canon.
iaind
Jul 25, 2011
353
I have some Canon batteries that 5d2 recognises but 5d3 does not after upgrade.
sama
Feb 23, 2012
257
It's likely that there are too many counterfeits out there.
Genuine and decoded third party batteries are fine on my 5DIII.
