tripod head advice
stevelee
FT-QL
2,379
1,063
Davidson, NC
I have a Sunpak Ultra 6000PG tripod. It came with a trigger head. Until now it seemed convenient and adequate to my needs.
A few weeks ago I got a 100-400mm II lens, and used it handheld at first. When I tried it on the tripod, however, the trigger worked OK for gross adjustments, but at 400mm I had a lot of trouble getting the composition just right. When I let go of the trigger, the weight of the lens, I guess, would change the aim. With practice, I could get closer to what I wanted in 3 or 4 tries, but it was still a pain. Of course the tripod was screwed into the foot on the lens, not the camera.
While the tripod is relatively lightweight, but it seems to support the 6D2 with that lens OK. So I think I need just a different kind of tripod head to use with the telephoto lens, maybe something with micro adjustments, or at least something that will lock where the lens is, rather that moving around when I let go.
Would any of you recommend any particular type of head for this purpose? Is the screw something standard, or would I need to get a head that was specifically compatible with the Sunpak?
Hector1970
1,554
1,162
Sometype of a ball head would be best I reckon.
It all comes down to price.
Gitzo and Really Right Stuff and Acratech make lovely ball heads but they are expensive.
Sirui make very good value ball heads.
Weight is relative I suppose. I don't find the 100-400 II the heaviest lens to use.
It doesn't need a heavy duty tripod / Tripod Head.
But in general with Tripods and heads I think its best to buy once and make it a good one
No idea about a Sunpak tripod but usually they are a standard screw site and often come with an adapter for the small size connections. A common standard for base mounts on photographic tripod equipment is a 3/8-16 screw (a screw that is 3/8 inches in diameter, with 16 threads per inch) on the tripod legs, and a matching receptacle on the tripod head.
stevelee
FT-QL
2,379
1,063
Davidson, NC
Thanks, guys, I'll check those out.
I like using the lens handheld. It's a lot a "just because I can" thing. With four stops of IS and a wide usable ISO range in the 6D2, that works surprisingly well, until my neck and/or hands get tired.
But I made a time-lapse movie of the bird feeder next door. I obviously needed the tripod for that. And it did involve just getting the aim right in the first place, but it cost me valuable time when the birds were there in good numbers. And even though I was relatively far away, the more fuss I made with the camera, the more birds I spooked.
I tried shooting a nearly full moon handheld. It was high enough in the sky that the weight of the lens on my head made it tough to focus manually. Luckily the AF shots came out great. A tripod and using the flippy screen would have been much more convenient. This is a 100% crop converted to JPEG for the web. I didn't apply any corrections such as for CA. Perhaps ACR did something behind the scenes before I saw it. In my experience, a full moon is just about a worst-case scenario for CA.
4,549
448
57
Hi Steve.
If you are doing things like moon shots or other static targets I’ll give another vote for the Manfrotto 410 geared head, I use mine for the 100-400 L II with either a 1DsIII or a gripped 7DII a friend has the newer MHXPRO-3WG which is made from a techno polymer (plastic ;D ) it has triggers for the gear release for coarse adjustment instead of twisting the outer knob, he prefers this due to having arthritis in a couple of finger joints, I dislike it for its cheap plasticy feeling and for using an RC2 (200PL) plate. The 410 geared head uses a 410PL which is a much larger plate with a better locating system than the 200PL, I have an Arca Swiss clamp screwed to mine!
For moving targets I have a gimbal head which is also fairly good at not sagging or creeping when locking it off if you want a one size fits both solution I would go with the gimbal, mine is a Benro GH2, moderately expensive but not up with the Wimberley!
I suspect some of the sag may be the tripod, this looks very like the tripod and head my friend used to have, it is a very light support and while you are holding the trigger grip you are supporting the bulk of the load, letting go of the handle returns all of the weight to the tripod causing some flex in the legs! The gear head will eliminate most of this effect.
If you're on a budget (like me) the Joby X Ballhead works great and is only 50 bucks. I have two of them on two tripods and they are surprisingly well built and strong. They hold the Sigma 150-600mm lens on both my 80D and 6D2 just fine, and even smaller lenses even better. I have them mounted on my Manfrotto 290 dual tripods and they are actually the best ballheads I've found at this price range and beat out several other even more expensive ones (I've been through a few).
I actually figured this out by accident.....I kept buying cheap ballheads trying to find a strong one and ended up pulling the JobyX head off my big gorilla pod one day and mounted it to my manfrotto tripod....it's been on there ever since! It worked so great I ordered another one for my other manfrotto tripod.
Here's the link....
https://www.bhphotovideo.com/c/product/680971-REG/Joby_BH2_01EN_Ballhead_X_Black.html?ap=y&gclid=Cj0KCQjwuYTYBRDsARIsAJnrUXBRR5Rw2YKKx__EyRK3hnu3q5GsmQUss3Sn4Enfnu02bNn84MPVSlEaAhZPEALw_wcB
3,368
570
Having looked at the tripod you mention on Amazon, that ballhead looks way too small for the size of gear you are putting on it - I would go for a midi-sized ball at the very least.
Trigger heads are fine for the sort of think you want to do but make sure you go for a 'heavy duty' version. For relatively stationary subjects is the geared heads that others have mentioned.
One left field option is a gimbal head - you have slider plates that enable you to set the camera on the centre of gravity and when you release the camera it stays exactly where you left it, no matter what position it is. These range from $40 to several hundred but even the cheaper ones are pretty good: I have a generic one costing $50 (Beike BK-45, but they come under many brands) and a Lensmaster one three times as much and each has pros and cons.
stevelee
FT-QL
2,379
1,063
Davidson, NC
Thanks for looking. Yes, I've since found stats that suggest my tripod is good up to 11 lbs., but that trigger head is similar to one I saw rated for 3 1/4 pounds. The lens weighs more than that by itself, so you are quite right.
No more than I plan to be shooting with this lens on a tripod, I don't see going with the pricier suggestions, ideal though they might be for the task. That's not to say I won't upgrade further if I later find myself using the tripod/lens combination more than I expect now. I'll save all these suggestions even after I get something I think appropriate for now.
pwp
Oct 25, 2010
2,530
24
If you go for a ball head, I'd strongly advise against Induro. Even the bigger ones, at full lock tend to drift. It's inexcusable. What I would suggest in the ball head line is Sirui. I have a couple. They're beautifully made, lock precisely and firmly and are very modestly priced.
I may have mentioned it here on previous posts, but Sirui used to manufacture for KIRK before breaking out on their own. Their manufacturing levels are a match for Kirk's very high standards.
Trust Sirui. Read some reviews.
-pw
D
Deleted member 91053
I would echo PWP's comments. Sirui make some great ball heads. Look at their KxxX range, I use the K40X and it will cope with anything Canon/Nikon currently make. No ball heads are not ideal for the largest lenses but my K40K does not creep with my Canon 800 F5.6 L IS.
Have a look at the K30X - this would probably suit your needs nicely.
P.S. Consider a better tripod when you can afford it.
stevelee
FT-QL
2,379
1,063
Davidson, NC
Thanks for all the good advice and wide range of options. After considering them, I have ordered a Sirui K20X. With the holiday weekend, it is supposed to arrive here on Thursday. With a class reunion and houseguests, it might be a couple weeks before I have time to give it much of a tryout.
It is quite possible that the tripod will indeed flex some, so there can still be some shifting. If I ever decide to get really serious about telephoto photography, I won't hesitate to invest in heavier gear. The current tripod is rated for 11 pounds, and that's probably more than I want to carry around these days as it is.
My photography lifestyles mirror my retirement activity modes. I travel, leave my DSLRs at home, and shoot a lot of pictures with my G7X II. Otherwise, I stay home, go to concerts, plays, sports, and lectures at the college; do projects on the computer, including post on those pictures I took while gone and my 78 rpm project for the neighbor's 90th birthday; and do photography projects with all my good gear or just mess around with them and sometimes luck into some nice pictures. I do hope to do a "staycation" with a rented TS lens (probably the 24mm), and maybe even include some day trips within that week. The tripod, and probably the new ball head, will be essential for that.
And I have collected these messages on my computer so if/when I am ready for an upgrade, I'll have good recommendations to start from. Thank you all.
stevelee
FT-QL
2,379
1,063
Davidson, NC
I got through the reunion weekend, and my guests have left. So after a late afternoon concert and reception, I went out about 8pm with the new K20X on the old tripod and tried working with the K20X. It is a vast improvement over the trigger head. There is still a little drift, probably, as suggested above, by the tripod settling a bit when I'm no longer supporting the lens with my hand. This improved with practice on my part, also. I can live with this set up for a while.
Here are a couple of 100% crops of shots of cardinals. I didn't do much of anything to lessen the noise from the high ISO and nothing to sharpen beyond the ACR default. Noise will appear even worse, since, at least on my computer, the pictures are shown enlarged further.
400mm f/6.3 1/320 sec. ISO 12,800
400mm f/5.6 1/320 sec. ISO 10,000
For a close focusing test, I chose a knot on my deck. This is the whole frame reduced in size for posting here.
400mm f/16 1/60 sec. ISO 40,000
Thanks again for the help and suggestions.
ISv
2,612
7,574
Stevelee, your tripod/ball head combo are way under the requirement for the camera/lens (Tamron 150-600) that you are using. I use similar camera/lens (by weight) combination on more sturdy tripod/head and sometimes (huh, many times!) it's not enough: the surface under the tripod is not even (you can correct this if you have time), it's not hard enough: no way to correct, heavier load (all together tripod, camera etc.) is better but never perfect. The ball head on hard surface has to keep the focus point rather steady. I was using Kirk BH-3 ball head on Feisol CT-3401 (the older generation, in that time Feisol didn't have distributor in USA) and it was not steady enough. It was working well when used with 105mm macro lens but with my Nikon 200-500 it was not good. Now I'm with the Feisol CT-3442 Tournament tripod (I just manage to break the spider of the old Feisol during a hike, otherwise I don't think they are much different in terms of sturdiness) with variant of Markins Q-20 ball head.
I think the ratio of the given max load for tripod/ball head to camera lens should at least 3:1 (I prefer ~5:1). I understand that the weigh limits (hiking) and unfortunately the cost limits are important but I went from few cheep combos to what I have now and calculating the money it was better to buy the new one from the very beginning - and as I already mention it's not always enough...
I have seen very good pictures of birds from you and you deserve better support for your system! I'm not sure how Markins are doing now, but you may choose the RRS as well (and yeah, even more expensive... but you will use them for long time!).
greger
7D
Jan 1, 2013
259
I have a Manfrotto 055 Pro with a Manfrotto 498 Ballhead mounted on it. I get creep with my 100-400 lens mounted. The solution was to loosen the friction adjustment until I had the subject in position, then tighten the friction control knob and then no creep. I had to use live view to see the subject and frame it. It took some fiddling around but worked in the end. Cheaper than buying a new tripod head.
