Hi Guys did anybody have any idea what is the maximum focus distance for 35mm F1.4 II with 12mm extension tube is it okay to be used for a headshot with it. Or is only good for macro photography :-[
cheers
cheers
azizjhn said:is it okay to be used for a headshot with it.
cheers
niels123 said:The result, focused at infinity.
Bernd FMC said:azizjhn said:is it okay to be used for a headshot with it.
cheers
Why should you use an 12mm Extension Tube for a Headshot ( Headshot of a Frog ? )
EF 35 1.4 II and Extension Tube in my Bag - but soon tested by Niels ...
neuroanatomist said:niels123 said:The result, focused at infinity.
Tecnhically, the focus on the lens is set to infinity, but with an extension tube behind the lens, from an optical standpoint the ability to focus at infinity is lost.
azizjhn said:Hi Guys did anybody have any idea what is the maximum focus distance for 35mm F1.4 II with 12mm extension tube is it okay to be used for a headshot with it. Or is only good for macro photography :-[
cheers
Mikehit said:Try it. Set the lens to infinity, point the camera at a subject and move closer until it is in focus. 15 seconds tops.
Unless you are trying to focus across a pit of tigers or something....that may take a little longer.
