Opinion: A Material Delay – A Likely Reason for Camera Delays and Production Issues
Manufacturers will need to consider alternative alloys then. The Nikon F2 had a cast aluminium chassis with brass top/bottom plates and this seems to have been how professional cameras were generally designed before the move to cast magnesium alloys. Nobody complained about that and I haven't heard of anyone with the slightest trace of sense say the F1-F3 aren't durable cameras for professional use. Even the EOS-1 had an aluminium frame. Engineering polymers might be the way forward.
I guess it comes down to what trade-offs work for you?
I'm not sure about the equipment differences of producing either for a camera chassis.
Aluminum Die CastingMagnesium Die Casting
Cheaper than magnesiumCostlier than aluminum
Alloys are mainly cast using a cold chamber equipmentMost die casting alloys require hot chamber equipment
Casting cycles are longerHas very short casting cycles
Parts are more stable under stressHas poor tensile strength and not so stable
Parts are Heavier than magnesiumParts are lighter than aluminum
Cannot achieve thinner wall than magnesiumCan achieve thinner wall than aluminum
Has excellent corrosion resistanceHas poor corrosion resistance
we're all going to be metallurgy nerds at the end of this.
and here y'all thought it was just a canon rumors site.
  • Haha
Let's not forget stamped and welded steel alternatives, including stainless. Or indeed Zinc. Some compromises will have to be made. The current compromise seems to be that we pay more while they produce less at a higher cost and can't supply according to demand. And we're not getting that nice brassing that you get with older cameras over time. Maybe the market prefers this compromise for mid to upper tier cameras
This market is certainly allergic to plastics from a marketing standpoint, but there are some pretty remarkable types. No idea what they cost.
Interesting opinion. Got me to thinking that photographers probably have several lens or old bodies that are never used; canon should offer option to collect for recycling and reward with discount for new camera etc
still 60% higher than before all this happened, it's easing, but it's still a problem. The spike was SO high that it's distorting the fact that it's still significantly more expensive.
Then we have .. who's getting it? [...]
Your theory puts Apples "Macbooks are made from 100% recycled aluminium" claim in a new light as well, combined with the increased marketing on the trade-in offers.
Fascinating article and points to what is likely a major contributor to camera and lens shortages and delays.
I wonder if another possible contributor is a shortage of resistors and capacitors. Even the most modern of electrical circuits are going to use considerable numbers and I have a feeling there are a couple of factories in China which supply everyone. Capacitors also use various rare earth metals of which China is the major producer. Some of the factors which contribute to magnesium shortages could also apply to the production of resistors and capacitors, perhaps even more so when the components are miniaturized.
Both modern cameras and lenses will need resistors and capacitors.
Interesting point - my initial reaction was that I'm surprised that the amount of magnesium camera manufacturers use for upmarket bodies (surely not that large in world magnesium production terms?) would be affected by shortages / changes in demand by other industries. But, I guess a shortage is a shortage. They were obviously affected by chip shortages a couple of years ago, and their usage can't be that high in world terms.
It's also the case that magnesium is being researched and developed for use in EV batteries, as an alternative to lithium-ion batteries. If that comes to fruition, then whatever shortages there are now are going to be a drop in the ocean compared to the future!
1 R1 camera needs by far less magnesium than an EV's battery but is comparable in price..
So the money should favor the camera!
I give the theory a wholehearted *maybe.*
A producer cannot source a given material will likely design for a different material.
That's easily overcome. Just put a few carbon fibers in it and nobody cares about the plastic anymore
I'm sure researching new materials is an ongoing thing.
Canon is a manufacturing company... so they R&D a lot of their own production tools and processes. You're not doing that in a couple of years for a quick pivot.
Retooling is not a flick the switch sort of thing. Others with more knowledge can chime in.
However, what if you can't get the production machinery to utilise your knew material? Retooling is not a flick the switch sort of thing. Others with more knowledge can chime in.
Canon likely does not do the casting or post machining. If your vendor of choice can't work with a new material, you go to a different vendor.
Most large companies with hardware production consider Diminishing Manufacturing Sources / Material Shortages (DMS/MS) a major risk, and execute accordingly. In my industry, for example, we are typically required by contract to ensure we have at least 6 years to end of life for newly developed hardware. However, that doesn't always work out. While there are industry tools (Accuris BOM Intelligence, SiliconExpert, etc.) that predict availability, sometimes we get surprised by companies shutting down entire lines, and if form/fit/function replacements aren't available, we have to re-design. I have not run into material shortages for metal, but have for circuit board laminates.
