RP problem
martin_p_a
Canon Rumors Premium
Jul 30, 2019
25
30
Montreal
Hi,
I just bought my very first RF lens and noticed something while playing with it. Since I didn't have any lens with a control ring, I had never played with the settings to change what it mapped to, but now that I have, I realize the setting isn't persistent.
I changed it to be mapped to the ISO, but every time I turn off my camera, it reverts back to the default setting. I don't know if that is a flaw with the most recent firmware update, as I updated my camera's firmware before getting the lens.
Anyone has had that issue or know how to fix it?
Thanks
  • Sad
First: I do not have an EOS RP Second: I do not know you background, sorry if it is to basic.
But maybe there are two places to set the ring function: Somewhere in the "normal" menu but too in the Custom Functions menu section. As far as I remember all the custom functions are persistent ...
... just checked the german manual because I am generally interested in the RP or maybe an R:
It is only defined in the Custom Function menu (forth group, F.Fn III ...) after the current german manual so it should be persistent ...
One last idea: If you use a custom mode C1 ... C3 it should make sense to store the config for the lens ring for that C mode after setting it in the custom functions ...
Thanks! Turns out 'm an idiot and you are right, it was just in my custom settings (that's where I live 99% of the time) and I just needed to adjust them. Definitely thought that setting was independent from the custom settings, but they are not. Everything works fine now.
An "idiot," which you definitely aren't, would not be intelligent enough to ask for help here! Cheers. So glad that was nothing to worry about!
You are no idiot. I ran into the same problem several times but do not tell it to others :)
  • Haha
