I received my copy of this lens several days ago, and I admit that it's a bit of a head-scratcher for me. First off, I ran a series of shots of a static target at different distances in order to calibrate it with the Sigma dock/optimization software. I achieved razor sharp results at f/1.4 after dialing-in the appropriate adjustments for each distance on the scale. I did use a tripod, an extremely bright halogen lamp (EV 10, at least), and center-point focus only for the calibration. I also played around with live-view focus which obviously achieved excellent quality and consistent results. After calibrating with the dock (each zone, save for infinity ended up at approximately +10 or so) I took the lens out for some test shots. The results were somewhat inconsistent, as others on this forum have reported. Many shots were spot-on, but some were confusingly out of focus - and often by a quite a wide margin. I deliberately kept the lens at f/1.4, but made sure shutter speeds were never below 1/200th. I probably should have noted what points on the 5d3 I was using when the misfocused shots were taken as I believe I did read a post on this forum that mentioned problems with off-center (or perhaps non-cross-type) focus points and this lens.
Next up, I attempted to AFMA with FoCal for kicks. FoCal's AFMA module absolutely hated this lens and reported 'poor' confidence (red color) in two complete runs. I didn't bother saving the logs. Next up I used the FoCal's AF consistency module which reported 97.5% consistency with phase detection... weird. I wonder if I've not received a dud lens, or if my old hands are shakier than I truly realize. I do own the Sigma 35mm f/1.4A which is an absolute gem. I have no problems whatsoever with the 35A in terms of auto focus. Sure, 35mm has lots more DOF at F/1.4, but I just can't miss with it.
Thoughts, anyone? I see that some people have already exchanged their copies of the 50A (even several times)... Thanks.
Upvote
