Speedlight help
Okay guys I have a question for you. I have an assistant who has a 5D Mark II and a 6D. Both cameras when using a speedlight, either the 580 or 430, will not emit the AF focus assist beam. Both flashes work good on my cameras so the flashes are good. And to throw a wrench in everything, when put on the green mode, the AF light comes on, so it must be a setting. I crawled theough his settings and his speedlight custom settings allow for AF assist beam. I don't see anything stopping it. Any suggestions?
Glad it's sorted.
@RLP, the assist beam works in One Shot whether AF is assigned to the shutter release, a back button, or both.
Edit: I don't recall if the AF assist works in AI Focus mode, and I can't check since the 1-series don't have that option.
neuroanatomist said:
Glad it's sorted.
I use AI Focus and the beam works in that mode. So AI Servo is a no-go in that regard. Thanks for your help! :-)
