Wide or ultra-wide angle with excellent corner performance
  • Thread starter Thread starter JoaoPedro
  • Start date Start date
PavelR said:
It's not as sharp as the 24L TS-E II, but it's very similar to the 35L f/1.4.
scarbo said:
24/1.4II is visibly worse than 35/1.4 thus for example video is much better with 35/1.4.
Actually 35/1.4 is my widest rectilinear lens because I am not able to manually focus with 85/1.4, 135/2, thus I do not have 24TSII...
To me, there doesn't look to be a difference, however, how lenses act in the field is far more important to me and if you need wider than 35mm, then the 35 f/1.4 isn't really going to be much use. 35mm is barely wideangle. Generally speaking, a 24mm lens is a landscape lens (although it does of course have other uses) and at f/8 to f/16 (by which time diffraction degrades sharpness), the 24 f/1,4 is plenty sharp enough, giving very good detail. It also has nice tonal qualities and contrast. From the reviews I read when trying to decide what to go for, the Zeiss 21mm was a similar sharpness overall (although possibly slightly sharper in the corners), agian with good contrast, but with a different look, which could suit some more than others.
mrsfotografie said:
extremeinstability said:
http://www.lenstip.com/200.1-Lens_review-Samyang_14_mm_f_2.8_IF_ED_MC_Aspherical-Introduction.html
They have the 14mm F2.8 Samyang beating the 14mm canon in most everything except distortion. $400. Mine just arrived today and so far I wouldn't expect a whole lot more from the corners of such a lens. The 24 F2.8 II canon I just got is also good towards the corners full frame.
http://www.photozone.de/canon_eos_ff/532-samyang14f28eosff?start=2 Just look at the samples on there. Kinda crazy resolution. Maybe 14mm is too wide for what you want?
Considering the 14mm F2.8 Samyang myself as the 14L II is out of my budget for such a specialty lens. Am a little worried about possible QC issues with the Samyang though, it really is that cheap! ::)
14mm is in! A few quick shots and I'm impressed with the whole package for only 320 euro's 8)
Cool. Mine is pretty impressive so far as well. One thing I've noted is according to lenstip the canon only beat it in distortion, build and having autofocus. Pretty fast I'm noticing their vignetting results having it better than the Canon just isn't true. So Canon wins that one too. I'm not sure how useful it will be at F2.8. But anyway, lenstip has it -2.58 EV full open fall off, while they have the canon -3.00. I used the Canon earlier this year and it was clear pretty fast with this Samyang it's vignetting wide open was even more severe. Photozone has this the right way and backward from what lenstip says.
I also just bought a 50mm F1.4 and noticed in looking at the options lenstip had the sigma and even the 1.4 zeiss smoking the canon wide open and stopped down. Like the canon looked like ass. I look at photozone and the opposite again. Picked up the canon 50 1.4 yesterday and it is great. I guess I'm not so excited for lenstip reviews at this point. Or perhaps it's just reviews in general are in a way kinda pointless given how so many don't at all match up with others. Like you have to find 4 or 5 and pick the winners that way. Or just buy the dang things.
Figured since I'd been praising the samyang over the canon so much that I'd mention this anyway. You stop that thing to F4 and still a lot of vignetting but by F5.6 it's a non-issue and gone by F8. I'm amazed it is so sharp even wide open though, corner to corner full frame. Also the flare deal is a nice thing to see as well. I can point it at the sun with no worry. There's only one small angle to hold it with the sun way in the corner to get that flare to shoot across. It's such a tiny range it's not an issue.
JoaoPedro said:
Good evening to all,
(have) 20-35mm L f2.8: Much better than all the previous ones in the corners and at any focal length, but with two probems: the minimum focusing distance is too long, only 50cm; and the lens is very prone to flare.
Is there any chance a short extension tube would help with minimum focus distance problem? That doesn't help with flare, but might help for many shots. I'm just assuming that if you're focusing inside 50cm you're willing to give up infinity-focus.
It's too early to report back on my experience as I still have to take the thing out in the field. I'm not too worried about its shortcomings though as resolution and a lack of chromatic aberration are the highest priority to me. Distortion and vignetting I can live with as I intend to use it in a more artistic sense - not for architecture etc. The color rendition looks good too at first glance. I'm a happy camper and looking forward to my first photo-shoot with it ;)
I'm interested in this as well. Definitely not a lens I'd be looking for for architecture, or necessarily for landscape although I might use it some for that occasionally. With 14mm you can do a lot different things artistically!
Here is one from last night with a couple full sized crops. I didn't do any sharpening just the default setting in CS6 raw converter. Pretty good even on the edge to get the bare tree tops showing way out there.
http://www.extremeinstability.com/stormpics/2012/lake.jpg
http://www.extremeinstability.com/stormpics/2012/lake-edge-crop.jpg
http://www.extremeinstability.com/stormpics/2012/lake-center-crop.jpg
I just got that lens, the 50 F1.4 canon and the 24mm F1.4 canon. I plan to do some examples on the site like full sized crops at various apertures, mostly for full frame corner examples. So fwiw there'd probably be more examples of the samyang on that. Also do the real world vignetting samples. From a brief glance at some I did, it doesn't seem the wide open corners are really any softer than stopped down. So you don't even need to stop down for the corners. Vignetting quite a lot happier at F5.6. And even the heavy vignetting at F2.8 can work obviously, so long as it's not a very high dynamic range scene, which you cold then count on banding when prying that open.
I don't know what I shot that at. Between F5.6 and F8. Probably F8. It was at 1/8th a second with no mirror locking up done. (my stupid 5D II won't shoot correctly with live view on either...shows it right by the photo is way blown out....turn live view off and take it instead and it is fine...annoying)
Great colors in the sky and reflected on the lake. Any way you could try out a more well lit scene and do full sizes crops of the corners and edges as well?
Yeah I can eventually. Waiting on the 24 to get back on Tuesday then run them all through some paces. But there are some great full size examples to look at here: http://www.photozone.de/canon_eos_ff/532-samyang14f28eosff?start=2 The two lower left ones in particular were pretty good for judging.
Looks to me like it's pretty sharp towards the edges/corners, although with the corners you get that awesome crazy perspective distortion 8) I'm liking this...I think I'll put this on the list for a holiday buy if they do a sale and/or I find the money. Or I win the lotto and buy all the rest of the lenses on my list. I can dream, right?
Damn, I cant believe how awesome this lens is for its price. I just checked out photozone's samples and the ones in samyang flickr groups. Freakin sharp and lovely contrast! O_o The corners are amazing for its class!
[/quote]
Had the same problem with my 60D in Live View Mode : exposure all messed up and I kept cursing against my poor camera... until I used the eyepiece cover !!
For the 5D II, see User Manual p.100 ... does that help ?
good luck :)
