Are the Canon brand remotes worth the much higher cost?
I had a Vello RS-C2II remote fail me when I was trying to shoot long exposures of waterfalls. It worked fine at the first waterfall, then stopped working. The rest of the day I had to use the timer on the camera to give it time to settle after hitting the shutter button. The lack of the remote also prevented me from using bulb mode without camera shake.
Later I did some troubleshooting and found the remote would work if the cable was held at a certain angle. I guess wiring is broken or frayed at the end where the wire enters the remote.
Is the Canon RS-80N3 built much better than the Vello (and other third-party)? Trying to figure out if I should spend $47 on the Canon or buy several of the $8 Vellos and replace as needed. I'd rather not have a repeat of the remote failing me somewhere.
