sportskjutaren said:As a professional sports photographer i would not use that.
The major reason is shutter speed.
Normally i use a shutter speed that is 1/800 or faster.
White filming requires shutter speeds that are a whole lot longer.
Also, prefer higher resolution. Since i crop most of my images.
(My work can be found here: http://jkpg-sports.photo/ ).
There's nothing stopping you from using 1/4000th per second in video mode if you want. I think you're confusing shutter speeds needed for smooth motion (1/50th for 24fps video, 1/60th for 30fps, etc...) vs any speed you want for stills. There's no limitation. You can manually set shutter speed for video capture now with current DSLRs. It's just that, were you to playback 1/800th or 1/8000th second shutter speeds in motion at 24fps, the MOTION would look VERY choppy, but each frame would be a perfect 8.8MP RAW still (in the case of this rumor). So yes, it could absolutely work.
Upvote
