neuroanatomist said:Marsu42 said:Don Haines said:17 or 18 mm is not wide angle enough for APS-C and landscapes... you can cheat by taking several pictures and stitching them together, but if you have people in the shot it just will not do... You really need 10mm...
Imho "landscape" and "ultrawide" are not synonymous, my 17-40L is quite nice at least for what I shoot on crop. And 10mm less still don't capture the 360 degrees world around you and you still might end up doing panoramas which usually also works ok. The reason for uwa is more that you *want* the distortion for creativity, not to necessarily to "take it all in" as Ken Rockwell correctly remarked.
+1
I often use my 70-300L or 100-400L for landscapes.
+1 as my best cityscapes are at 200mm. Compression makes modern and brutal urbanization even more oppressing.
But in that subfield, UWA is indeed "to take it all in" as many things can block the shot...or go back to the core of land/cityscape: location, location, location.
Upvote
