Samyang to announce a 14mm f/2.8 RF and 85mm f/1.4 RF soon
EOS 1D MK II
7,820
454
Samyang has plans to announce 8 new lenses by the end of Q2 in 2019. The first lens they announced was the 10mm f/3.5 for the EF mount yesterday.
It now that Samyang will launch two new manual focus lenses for Canon’s RF mount very soon.
The two lenses coming will be a 14mm f/2.8 RF and an 85mm f/1.4 RF, as mentioned earlier, these are both manual focus lenses.
We’re not sure if these are simply mount conversions of existing lenses or new optical designs.
Continue reading...
1Zach1
Dec 3, 2013
70
54
Well I was planning on getting the EF 14mm version, but I’ll wait and see how these come out.
BeenThere
Sep 4, 2012
863
193
The OP photos of the lenses appear to have built in extensions to account for the RF flange distance difference from EF. So probably the same old optical formula with a new mount and MF.
Tom W
Sep 5, 2012
230
164
Strange then that they are using the older manual focus optical design and not their newer AF one.
They probably don't have the technology to do AF on the RF mount yet. They're barely getting into AF on the EF mount.
Just a thought - as noted earlier, they seem to have taken the EF lens and put a different mount on it. The 14 mm in particular would benefit greatly from the shorter flange distance, which would require much less retrofocus in the design.
maves
24mm TS-e ii is life!
Sep 21, 2017
26
26
Tasmania
For the 14mm I think you'd be better off with the EF mount version, then you can use the drop in filter adapter.
This actually goes for most Lenses that don't easily take standard filters.
bergstrom
Photographer
Feb 23, 2015
160
22
so samyang made manual, then moved to Af and now ith the ef they're going back to Manual? A few steps back isn't it for them? Prob best just to splash out and get a proper AF lens.
flip314
Sep 26, 2018
257
357
Manual focus won't matter for the 10mm and probably the 14mm since the DOF will be so great (in most cases you can either focus as close as possible, or at some rough estimate of the hyperfocal distance)
For the 85mm it is a big issue.
Incidentally, I wonder if the APS-C version of this lens registers as a FF lens on the RP? Third-party lenses may let you get away with using a crop lens in 4K which is otherwise disabled on that camera.
FramerMCB
Canon 40D & 7D
Sep 9, 2014
401
93
52
But either on the R or RP won't it be easier to manually focus lenses than on a DSLR? I hear that is one of the benefits of mirrorless...
Reactions: JoFT
SwissFrank
Dec 9, 2018
315
119
TOTALLY agreed. Any lens wider than 50mm can be substantially smaller, lighter, cheaper, and sharper when it's a non-retrofocus design. (Retrofocus means the lens has, on top of all the other factors it's balancing, a requirement to have a huge distance between the back of the lens and the sensor to allow the flipping mirror. When you add that iron requirement for SLR lenses, every other factor instantly gets worse.)
Reactions: JoFT
SwissFrank
Dec 9, 2018
315
119
PRETTY MUCH agreed. At f/2.8, you can certainly focus a 14mm wrong, but the hyperfocal at f/2.8 m is: focus at 2m30cm, and everything from 1m15cm to infinity is in focus. At f/8, focus at 80cm, to get 40cm to infinity. (Here's a table: https://www.photopills.com/calculators/hyperfocal-table)
A little off-subject but I've always thought that "Hyperfocal" would be a useful focus mode. As you adjust f-stop or zoom, it adjusts the focus to compensate, and displays the resulting near distance in the viewfinder. Related would be a mode to focus on near and far subjects, and have the camera focus to get them both and to adjust f-stop as well. (I seem to recall something like that on the EOS-3, but may be confusing with the multi-spot spot-metering.)
jedy
Feb 14, 2014
99
28
Any third party lenses for Canon will have reverse engineered autofocus. I doubt Samyang has worked out the R mount autofocus yet and reverse engineering will never beat native autofocus for reliability. Also, don’t expect Zeiss to produce R mount autofocus lenses. Sony share their autofocus technology which is why that mount has autofocus lenses from Zeiss.
