Hi YuengLinger.
My Canon one for the 550EX is plastic, my cheap Triopo flashes have a brass insert in the base, I'm not certain which I prefer from an engineering point of view. If the brass insert is only knurled on the outside although it would be unlikely to split I think it could pull out easily enough. The plastic moulded thread would probably be equally strong in tension.
If the brass insert has a substantial groove or ridge around the diameter then the brass would be way better, problem is the only way for me to know the answer to the manufacturing method is to destroy one, anyone with X-ray gear care to check? ;D
YuengLinger said:neuroanatomist said:YuengLinger said:Two concerns: The included cold shoe/stand has plastic threads which can crack with overtightening, and with movement it can come lose from the boom just by unscrewing. I'd have no problem putting it on a stationary stand.
Depends on the flash. On the cold shoe/stand for the 600EX-RT (at least, on the four that I own), there's a threaded metal insert in that socket – I'd think that wouldn't crack and would allow effective tightening. OTOH, the cold shoe/stand that came with my 270EX II has plastic threads.
Interesting. What color is the insert? Obviously metal? I just double checked, mine are definitely just another shaped part of the plastic base. No insert. Stamped on the bottom of the stands is "V50-#5 >PA<" (Same as on the 580ex.) All made in Japan.
Upvote
