Fortunately, you don't have to be a Euclid or Pythagoras to take good photos.What I always enjoy about the square format discussions is that so many people think you can get a larger image out of the lens circle with a square crop. I barely passed geometry but I at least know that the total area won't change if you draw a square or a rectangle within the circle.
When I did a lot of wildlife photography I used it quite a bit, there's often downtime in the field and I'd pre-sort my images using the rating button to save time later.I use it all the time. After a big play as I’m chimping to see if I got the shot I star the best one. During halftimes and after the game I run through the captures and star the best ones. Much faster than doing it on the computer later and saves me a ton of time not having to cull through 3000 frames waiting for the computer to render them.
I’ve even used ratings to ID players I need shots of. Five stars for #38, four for #7 etc. then I can filter for those players.
Even during other events I’ll often rate shots. It sounds like you’ve never shot on a deadline.
Better still, design all cameras so that there's an *option* to transmit the image files by ftp direct to external memory, thereby eliminating most of the heat source?I think this design makes a lot of sense. One of the biggest sources of heat in the Eos R5 is the memory cards. By isolating them in the handgrip it should greatly contribute to a cooler running camera.
The truth is, barring a totally new technology, like optical circuit boards, a radical redesign of the camera body would seem a necessary measure to allow for the high levels of performance that this cameras will no doubt be capable of providing.
In all honesty, this is the most interesting thing I’ve seen in the mirrorless market in years. If it brings with it killer specs… and I suspect it will, then I’m definitely adding one to my collection.
Ergonomics is a personal thing. When I use a non-gripped camera, my hand is sore by the end of the day. I think mainly my 5th digit being curled under and even more the lack of weight to counterbalance a heavier lens – even the 24-105/4L feels unbalanced on my R, and the other day I was shooting with the (adapted) 11-24/4L and that was a whole other level of front-heavy.The body format in the Canon patent looks bulky too. Personally I prefer a more compact body like the R5, with the option to fit a vertical grip for specific situations where I'll be shooting a lot of material vertically, or when I want a longer-lasting non-interrupted power source.
I agree that ergonomics is a personal thing, although there are a few basic rules such as leaving a sensible gap between the grip and the lens - a problem with early Sony cameras. I've owned, hired or borrowed virtually every camera that Canon has made, at some stage. I found the 5D and 7D series handled extremely well. The gripped 1Dxii handled even better, but was just too heavy to carry, and I often shoot in very tight situations, sometimes with the camera on the ground, and need to have the lens as low as possible, so most of the time I prefer ungripped bodies. I can't get on with the RP, which I find much too small and fiddly, especially if using anything longer than a 100mm lens. The R5 balances well in my (largish but skinny) hands, with all the lenses I own (listed below).Ergonomics is a personal thing. When I use a non-gripped camera, my hand is sore by the end of the day. I think mainly my 5th digit being curled under and even more the lack of weight to counterbalance a heavier lens – even the 24-105/4L feels unbalanced on my R, and the other day I was shooting with the (adapted) 11-24/4L and that was a whole other level of front-heavy.
I used a gripped 7D and 5DII, which were ok but the integrated grip has a different shape that I find much more comfortable (the add-on grips bulge on both sides to accommodate transverse batteries, the 1-series only bulges in front). I also found the flex between grip and body to be problematic on a tripod, but removing and replacing the grip is a PITA.
Not at all sure how I’d feel about something like this patent design. Bulk isn’t a big deal (my camera bags are sized for pro bodies), but not sure about all-day comfort, and too much weight savings would be bad for me (as above, it’s more about balance than total mass).
