Question RE EF Lenses on EOS M and other APSC Cameras
I want to buy the EF 35mm f/2.0 IS lens to go with my EOS M. Currently I use the 50 f/1.8 via adapter and the native 22mm f/2.0 and 18-55.
My inclination towards EF lenses is in the interest of obtaining maximum image quality, and because I may want to pick up a full frame second body at some point, likely a 6D.
BUT I ran across an article recommending against full lenses on APSC cameras. The argument made sense but I had never heard this before.
The rationale was that the amount of light reaching the sensor is greatly reduced on a crop body camera such that an f/2.0 lens ends up being almost an f/4.0!
Is this a valid argument with an adapter, on a mirror less such as the M? Would I be negating the advantage of a good EF lens by using it on a crop body? Or does the adapter itself help recover some of that light loss?
I'd appreciate the opinion of some of you with more expertise than I?
Thanks!
Thanks. What I gathered from the article (by Tony Northrup), and I hope I didn't misrepresent his point, was that a full frame lens on a crop body wouldn't deliver the same amount of light to the sensor meaning that the seeming advantage of the lens wouldn't be so great on a crop body.
So by way of example, if I were using the EF 35mm f/2.0 on the EOS M would it be less bright at a given aperture than the native EFM 22mm f/2.0?
Thanks!
31,228
13,088
From a technical standpoint, I'd trust advice from a bowling ball more than advice from Northrup.
mvrbnsn said:
I was thinking that by using a good quality EF lens I would be gaining image quality. Right or wrong?
Right, because you're using only the center of a larger-than-necessary image circle, and lens IQ drops at the periphery of the image circle.
rs
Dec 29, 2012
1,024
UK
f2 is f2. So both lenses would have equal brightness on an EOS M.
The somewhat misguided point TN was attempting to make is that a FF f2 lens is capable of transmitting more total light (and a wider field of view) than a crop sensor behind the lens can capture.
However if you have a crop body and currently use an f2 lens, this new f2 lens will not fall short of your expectations. And it will only get better if used on FF.
It's a good move to get the 35 f2 IS especially when you know you want to go full frame eventually. There is no down side to it other than higher cost and awkward ergonomics on m3. Very high grade full frame lenses have great image quality from center to the outer edge of the image circle. Mediocre full frame lenses have decent IQ in the center but the outer edge sucks. If you use a high grade L lens on a cropped sensor you're wasting the outer edge and you're kind of carrying extra weight for nothing.
Tony's youtube channel is not that terrible but you always have to take his advice with a grain of salt.
jd7
1,064
418
OP, if you want to get a good understanding of shooting with full frame versus crop, I suggest having a look at this website:
http://www.josephjamesphotography.com/equivalence/
It takes a bit of time to digest it all (and I haven't worked through all of the maths in detail), but I found it very useful.
In practical terms
f2 is f2 in terms of allowing light density (brightness) to build up on the sensor. That means the exposure time for a given brightness will be the same whether you use crop of full frame. (The crop sensor will gather less total light though, simply because it's smaller.)
You need to multiply the focal length by the crop factor to work out the "equivalent" focal length.
If you assume the same framing, you need to multiply the focal length by the crop factor to work out the "equivalent" depth of field.
If you use crop, it crops off the outer regions of the image circle of a full frame lens, which are often the weakest area.
I shot with a Sigma 24-70 2.8 on crop for years before I got a 17-55 2.8, and I really regret it. The 17-55 focal length was much more useful/versatile for me than 24-70, when using a crop sensor. And the 17-55 was lighter, had IS, and longer zoom range.
Building a lens kit of EF lenses when you have a crop sensor camera doesn't necessarily help you as much as you might expect when you jump to full frame, as the way the lens performs and hence what you want to use it for will change. Of course, sometimes a lens can be very good and useful on both full frame and crop, albeit you are likely to use it differently. (And the exception to that is long lenses when you are going for maximum reach - then you will use it for the same things.)
In my view, the ability to use EF-S lens is an advantage of having a crop sensor which should not be overlooked (especially for wide angle and normal focal lengths).
That said, if you are looking for a 50 or 55 mm equivalent, fairly fast aperture lens for your M, the 35 IS will be a good a choice.
Sporgon
4,722
1,542
Yorkshire, England
Definitely recommend using the EF prime lenses on the M3 via the adapter. Three points: firstly their use allows you to benefit from the much misunderstood "disadvantage" of crop, that is the greater dof for a given aperture. This means you can shoot at wider apertures and benefit from more volume of light, less defraction for the small pixel pitch, faster shutter speeds, lower ISO etc. The M zooms are generally too slow to use in this way.
Secondly the flange to sensor distance on the M lenses is very shallow but those lenses are not tele-centric, so the light falling on the outer part of the sensor is coming in a one hell of an angle. There have been suggestions that the sensor has not actually been designed for this but rather been lifted straight from a dslr design. By using EF lenses with both a larger image circle and greater distance away, the light angle is much more acceptable, and the IQ is better, in fact it can be top notch in reasonable light.
Thirdly, a negative: the EF lenses via adapter don't focus or track as well, a you lose some other minor functions.
justmy2cents
EOS 7D II
Nov 21, 2015
4
Thanks!
A APS-C sensor has less than half the size of a FF sensor, so you'd have to use a larger aperture because the pixels are smaller. Or you could crank up ISO, but that would increase noise.
I think the baseline of what TN is saying is: if you spent a lot of money on FF lenses, you better get a FF body as well to make full use of them. And if you don't plan on going FF, buy crop lenses - if there are any good.
Sporgon
4,722
1,542
Yorkshire, England
I think he is wrong, or at least out of date. The crop sensors are now so good you can actually benefit from FF EF lenses as I outlined in my post on the previous page.
1,060
130
There is another catch on using FF lens on the APSC. The APSC sensor has a multiplication factor of 1.61 linear or 2.59 area. In order to fully utilize the resolution power of the APSC sensor, the FF lens must have 1.61 more resolution power than what is needed for the FF sensor. M3 has a resolution of 24.2 MP. It needs a FF lens with 62.79 MP resolution to fully utilize the resolution power of the M3. How many FF lens can make that claim?? It is unfortunate that Canon does not make a 35mm f2.0 IS EF-M lens.
10,673
6,120
You need to learn how system resolution works before making patently inaccurate comments like that.
Here is a start: http://www.canonrumors.com/forum/index.php?topic=26938.msg595091#msg595091
1,060
130
Thanks for pointing it out. I am fully aware of that. As per your quote says. When both sensor and lens resolution are matched. the end resolution is only 71%. If the lens resolution is only 66% of the sensor. The end resolution becomes only 55% of the sensor. That is 21 % reduction from the potential resolution. This is not fully utilize the resolution of the sensor. We spend money to buy expensive equipment, we want to get the most out of it.
31,228
13,088
How is it that, as you imply, your argument applies to FF lenses used on APS-C cameras, but not APS-C lenses used on APS-C cameras? Or do you believe that APS-C lenses intrinsically deliver higher resolution? Sorry, but I can't really see any relevance to your point in this discussion of using FF lenses on APS-C cameras. Yes, smaller pixels benefit more from higher resolution lenses, but the pixels of the M3 aren't all that much smaller than those on the 5DsR (same density as a 20 MP APS-C sensor).
If anything, since lens resolving power is generally highest in the center and drops toward the periphery, the benefit from using only the center of the FF image circle is quite significant – a glance at the 35/2 IS MTF chart shows resolution remains quite high through area of the APS-C sensor.
The illuminance on the sensor (for a given scene luminance), which (along with the shutter speed) is the factor that determines the photometric exposure, the quantity to which the sensor responds, is determined by the f-number of the lens. Period.
Best regards,
Doug
10,673
6,120
Best regards,
Doug
The point is the sensor receives photons as a function of area, ergo a sensor that is less than half the size receives less than half the photons. That is why FF cameras are at least one stop better in ISO noise performance for any given exposure and output size.
Fleetie
Watching for pigs on the wing
Nov 22, 2010
375
5
52
Manchester, UK
www.facebook.com
And the T-stop.
