I'll just put this here and see what happens:
https://petapixel.com/2017/10/06/nikon-d850-best-dslr-ever-gets-first-full-100-score-dxomark/
- A
- A
unfocused said:I find it confusing that it scored a perfect 100, yet the review discusses several areas where it is less than perfect and the data indicates that other cameras either beat or matched its performance on particular criteria.
Does this mean DXO will soon be turning the amplifier up to "11."
Talys said:I posted this on the other thread, but I think it's more appropriate here:
Why does the Low Light score suck?
2995 - Canon 5D Mark IV
2956 - Nikon D750
2862 - Canon 6D Mark II
2853 - Nikon D810
2660 - Nikon D850
After ISO 800 D850 has less DR, Tonal Range, and Color Sensitivity than 5DIV on the Screen measurements (it scores better on a bunch of Print measurements).
So anyways, since it is not a perfect sensor, by DXO's evaluation... does a future sensor that is better than the D850 score > 100?
AlanF said:Talys said:I posted this on the other thread, but I think it's more appropriate here:
2956 - Nikon D750
2853 - Nikon D810
2660 - Nikon D850
"Why does the Low Light score suck?" The fair comparison with Low Light Score is with a sensor with the same pixel density, namely the 5DSR, which has 2308. The 850 doesn't "suck" against that.
I use both the 5DIV and 5DSR, but I am not going to rubbish the D850 out of an irrational sense of tribal loyalty or to justify my purchases. I use the 5DIV when I want speed and for lower light, and the 5DSR when I want the best resolution. For most of the time I use the 5DSR at iso640 and above, where there is little to choose between the DR of the 5DSR and D850. I would love Canon to be spurred into action to produce an equivalent of the D850 because it is a magnificent piece of engineering. So come on Canon, make a 5DSR Mk II that regains the number 1 spot.
AlanF said:By that reasoning, the 26.2 mpx 6D II with its low light score of 2862 does "suck" compared with the Sony 42.4 mpx with its low light score of 3434. Mind you, I don't take DxOMark's scores seriously because, apart from everything else, noise in practice depends on the lenses available, degree of cropping etc.
AlanF said:There is no Nikon glass I would like for bird photography. I don't go for the 500/4 and 600/4 even for Canon as they are too heavy for me. The Nikom 200-500mm is too heavy, and several reports prefer the Tamron 150-600mm (it zooms in the same rotation as Nikon) and the 80-400mm is not a good lens. I do not know first hand but I have read that Nikon's don't have C1, C2 and C3 on the mode dial that store settings faithfully. Please correct me if I am wrong. I do want a Canon with the D850 specs.
I can't understand, why people are so concerned with an arbitrary score, weighted to base iso DR.ahsanford said:unfocused said:I find it confusing that it scored a perfect 100, yet the review discusses several areas where it is less than perfect and the data indicates that other cameras either beat or matched its performance on particular criteria.
100 isn't perfect. It's just a number. If memory serves, prior EPIC cameras and a medium format rig have scored over 100 before. This is just the first FF SLR to hit that mark.
- A
Talys said:AlanF said:There is no Nikon glass I would like for bird photography. I don't go for the 500/4 and 600/4 even for Canon as they are too heavy for me. The Nikom 200-500mm is too heavy, and several reports prefer the Tamron 150-600mm (it zooms in the same rotation as Nikon) and the 80-400mm is not a good lens. I do not know first hand but I have read that Nikon's don't have C1, C2 and C3 on the mode dial that store settings faithfully. Please correct me if I am wrong. I do want a Canon with the D850 specs.
Yes, you've described the logical conclusion that I've drawn as the "intellectual" reason to choose Canon.
Even though I don't own a big f/4, I'd like to own one, one day, and even though I expect I will use a gimbal for that, it's okay; I'd much rather the canon 600 f/4 than the Nikon 600 f/4 (for weight reasons). On lens under $3,000 USD, the 200-500 appeals on paper, but is much less friendly to carry around and shoot stuff with than Canon's 100-400.
It doesn't really matter if the D850 is super duper awesome, if there aren't matching, intermediate telephoto friendly to carry around. At the moment, frankly, the third party 100-400's are the best choice for carry-around, and I far prefer Canon's because of ease of MF, consistent autofocus, and MFD.
And sure, I, too, would love to see D850 sensor specs in a Canon body, though to be frank, I probably wouldn't spring for it, as it may be over the price range I like to spend on bodies. I am much more willing to invest in lens, because of the lifespan where they stay in their "prime" (ie when they aren't superceded by a better lens choice).
The less intellectual reason that I choose Canon is just one of preference. I like Canon cameras. And by the way, I would never buy another camera that didn't have custom dial functions like C1. It's like buying a car without a cupholder.
AlanF said:The Nikon AF-S NIKKOR 600mm f/4E FL ED VR is actually lighter than the Canon EF 600mm f/4 II; 3,810g vs 3,924g. You might have got the weight information from TDP, which has just the older Nikon 600mm f/4G AF-S VR and hasn't updated it.
