Tugela said:EF-S lenses are mass market low cost products. People who are serious about their hobby probably have mid to high end EF glass anyway even if they use a crop sensor camera, so moving to full frame is not really an impediment.
I'd expect most crop-body shooters to use EF lenses for primes and for longer focal lengths beyond their primary zoom lens, but I'd expect them to rely on at least a couple of EF-S lenses. Specifically:
- The EF-S 10–22 (or, in the future, possibly the 10–18) is the only lens that's ultra-wide on a crop body.
- I'd expect most folks to also use an EF-S lens for the primary zoom (e.g. an 17–55, 15–85, or maybe a 17–85 if they started shooting Canon crop bodies before those other two lenses appeared on the market), since the 24mm end of the EF zooms isn't particularly wide on a crop body.
When those folks move to full frame, that's more than a grand worth of lenses that they can't use, and will need to replace with EF lenses that cost about twice as much.
With that said, I suppose it depends on the shooter. If you can deal with 24mm as the widest range for your primary zoom (like shooting with a shorty 40 as your widest lens on a full frame), then yeah, EF lenses are fine. Or if you can deal with a 16–35 as your primary zoom lens (equivalent FF range 26–56), you could go that direction. Unfortunately, both approaches are a pretty significant compromise because EF focal lengths aren't a very good fit for crop bodies. If they were, Canon wouldn't build any higher-end EF-S lenses like the 17–55 and the 10–22.
Upvote
