24-70 II slight clicking sound when zooming
I would sure like to know what they changed and why they don't change it back... The clicking lenses will continue to appear because canon haven't said anything and therefor nor changing anything. It's funny, but I have owned multiple copies of a lot of lenses and it's always the oldest ones that work superior. And on top of that, with cashback and a weekend offer I paid 1000 dollars less for the 2470 brand new than it sells for now...and that's a loong time ago. Wth... I really feel for you guys that can't get a good copy...
Just got the lens back. Te service details say:
Your product has been examined and it was found that the af assembly was loose causing inaccurate auto focus. Electrical adjustments were carried out on the af assembly. Adjusted centering/tilt/best focus & cleaning. Product functions were confirmed.
Its still clickin' o_O
Hi everyone,
I too had this problem, so here's my story with the lens.
14-01-2014: I purchase this lens from a local store in Denmark, and got it home - Serial 042. Immediately I notice the clicking noise when zooming. The description of the problem is very similar to others. Slight 'ticking' noise when zooming from 70mm to 24mm. The zoom ring also feels quite tight, especially going from 70-24.
Despite this, I ran it through Reikan Focal and did an extensive AF test. I found it had quite erratic autofocus. While it certainly did achieve sharp results, the focus was all over the place, despite having run it through AFMA test and set it to its best (Required +6 on wide and +8 on tele).
06-02-2014: I take it back to the store, and luckily, they had a 24-70 on display. It did not have the ticking noise, and the zoom ring was also a lot smoother. They also had 3 other new lenses in the back, and took all of 'em out. 2 of them, serial 032 and 042 had similar problem as the one I purchased. The ticking was quite pronounced on the 032 serial, while the 042 was harder to hear, but it was there. The 3rd was a 096, and had the old lens cap - it was perfect. No noise, smooth zoom ring, just like the one on display, which also had serial 096.
I ended up exchanging it for the new 096 serial, and took it home. Did some AFMA test, it required +3 wide, and +4 tele. The AF results were similar to my other primes/zooms, with much more steady results. Sharpness was the same as the first one at its best.
I also noticed that the Aperture sharpness was very different on the 2 lenses. The 'ticking' lens started low in sharpness at 2.8, and steadily increased until 4.0 and slowly dropped until 10.0 where it dropped fast. The new lens was sharpest at 2.8, and dropped very very slowly until 10.0, where it started dropping fast like the other.
All tests were done in the same room, with the same light in the evening at 8,8 EV. Tripod at same spot, both at 24mm zoom at 1.2meters.
Hope this info helps someone.
I also want to thank you all for a great community, with lots of great info. I've read a lot on this forum, but this is my first post. I figure I could finally contribute with something :D
- Radjan
I've had mine since October 2012 and never had any clicking. It's always been smooth, nearly silent and extremely accurate AF.
However, the lens coating on my front element recently appears to be disintegrating (posted in the other 24-70 thread) and i've just sent the lens back to Canon (now Out of Warranty... grrr)... we'll see what happens, hopefully it doesn't come back clicking!
Gotta say, this is all pretty disappointing to read about a $2300 lens.
Did you have filter in it?
I have the same clicking issue for 2 months now. To late to get a replacement since I cut up the UPC for the rebate. I did not perform AFMA, but I can tell at 24mm its not as sharp compared to the ones I rented. There is really no point sending it to Canon. As they dont acknowledge the issues on this lens. I might just go back to primes and white lens.
Just test with the box or any other contrasty text and see if it's sharper with live view than with "normal" phase AF. If it is, your afma value is incorrect. If it's not, it might be less sharp copy or decentered lens.
good advice.
Wants to buy a 03xxx lens - very sharp, same click click sound. Go to another shop, get a 08xxx lens - sharp also, same click click sound!
At the end...is the noise indicating an issue or not? Did someone buy it such lens and kept for long time? How this evolves?
It's too soon to know. I've had mine for 10 months and it has a faint clicking sound, but no other issues....images are wonderful.
We may not know that for a long time... The other thing we don't know is what is actually causing the clicking sound. However, a clicking sound usually results from two parts coming into contact. The fact that some copies have the sound and others don't suggests it's not normal (no matter what Canon says). I can't help but think that over time, that's not a good thing – either those parts will wear down leading to a malfunction, or the friction will result in small pieces of those parts breaking off inside the lens, resulting in potential damage.
I had june 2012 copy i sold because it just had af consistancy issues canon refused to acknowledge. I just got a new black and grey boxed one today from bestbuy and it is an 082 batch (8-13) i think. The zoom ring is tighter and when i pick it up nothing feels loose like my original had felt like something was loose. It seems just as sharp. No dust or bubbles. I tried to mimick that youtube video and do not hear that same clicking noise so hope i got a good copy. Any suggestions to test before i send off the rebate upc?
The first I had with the clicking sound, there was no need to test it in anyway, it was there when touching the zoomring. The new one I got back when this thread started has worked perfect since then, and I use it a lot in all temps and weather, no issues found whatsoever.
Can anyone say if they have bought new lenses lately if they still click or squeak or have bubbles and or AF issues? Would be interesting to know if they're getting better.
>:( I agree with others that it is quite annoying that Canon doesn't seem to acknowledge this issue. One of the big problems with it, is that it doesn't do it every single time you use the lens. When you spend close to $100 to send it in to Canon, there is a good chance that the lens won't do it, while in there possession.
What the Canon technician told me was that they tried it 3 or 4 times and it didn't present with the issue, so they cleaned it and shipped it back to me. It was clicking within 4 images of me getting it back and using it...
They suggested it was the camera and told me to send that in too. I commented that it did it with my XSi, my 7D and my 5D III and my son's 5D II. Should I send all my cameras in, I asked? Yes, he said... No thanks... :(
The lens still does it periodically and yes, it still pisses me off! I'm going to sell it and get a new one...
Wow, those Canon techs are really clueless. The problem has nothing to do with the camera body. Obviously, the real cause is the shoes you're wearing while using the lens - next time, send those in with the lens.
My god, what the .. kind of answer is that? I have, luckily for them, never experienced that kind of useless attitude with Canon tech here. It's like they're paid to annoy you, not help you with an answer like that.
I'm surprised. I hope I will not run into this kind of support from Canon.
I had a problem with my 24-70 of Tamron. Battery drain while connected to the camera.
I contacted the servicecenter of Tamron. They acknowlegded the problem. Knew exactly what the solution was. I have sent it in and they replaced the circuitboard.
Exaclty what you should expect from support service.
