Canon XC15 Style Camera Coming with EF Mount? [CR2]
Canon EOS 40D
10,837
3,199
HTML:
We have been told a couple of times that a Canon XC15 style camera with an EF mount will be coming some time in 2018, one would think NAB in April would be the perfect time to announce such a camera.</p>
<p>We have <a href="https://www.canonnews.com/first-hint-at-a-hybrid-video-stills-ilc-camera">seen a patent related</a> to such a product, so that raises the possibility of it actually happening. We were first told about this camera before the publishing of the patent.</p>
<p>One of the sources did say that contrary to some popular opinion on the web, Canon considers the XC10 and XC15 to be a success with better than expected sales numbers.</p>
<p>No other specifications or information were given to us.</p>
<p><em>More to come…</em></p>
Oct 18, 2011
1,026
81
They are selling the XC10/XC15 on the premise that its good for reportage and B-Cam work, so having a changeable mount makes a lot more sense (even if it ships with a 24-240 lens, or perhaps their latest 24-105).
Though it'd probably make more sense to drop the handle, shrink the size a little, and compete as a Blackmagic Micro/drone style camera.
unfocused
7,184
5,484
70
Springfield, IL
www.thecuriouseye.com
EF Mount, but what will the sensor size be?
If it retains the same 1-inch sensor, then the wide-angle choices will be very limited, as the XC-15's wide end of 8.9mm is equivalent to about 27mm. Not many options in that 9mm or below range of EF, EF-S lenses (like none, except for the f4 fisheye zoom.
Going to an APS-C or Full-Frame sensor would solve that problem, but not sure what effect that would have on the form factor.
136
77
As an XC10/15 owner, my primary problem with the camera was the variable aperture lens. If it had been a consistent f/2.8, it would have been far more useful as a b-cam. It just couldn't keep up in low light. A changeable lens mount would fix this, but it would also ruin the very good IS and small size of the camera. As it was, the variable aperture lens was the maximum size the camera could handle without needing to increase the size of the body to compensate.
ExodistPhotography
Photographer, Artist & Youtuber
Feb 20, 2016
225
3
45
Phillippines
www.youtube.com
Guess they realized the main reason no one wanted one at that price point is that people wanted interchangeable lenses. Seriously if anyone wanted to be stuck with a single lens then the Sony AX100 was a more affordable option and has same sensor size. But very few will pay $2000 USD for a camera you can not switch the lens out on..
2,505
147
except the XC10/15 had a serious and broadcast quality codec. the AX100 has a consumer one.
760
103
Going with an APS-C sensor makes sense. If they can fit that into an M5, they ought to be able to fit it in this thing. Of course, they should have released it as APS-C with EF mount in the beginning. If it doesn't come with 4K 60p, it never happened.
XC15 style camera with EF Mount? They already make that - it's called the C100.
What Canon needs to do with the XC15 is increase the sensor size (or start using Sony 1" sensors, whatever they need to do to get better low-light performance and DR), and redesign the lens. SACRIFICE ZOOM RANGE FOR CONSTANT APERTURE PLEASE! And make the optics better, especially on the wide end. Cropping into 4k at 24mm on the XC looks bad - very soft and lots of CA. Just steal the 24-200mm f/2.8 that the RX10 II used and call it a day. Seriously.
760
103
Or they could just suck it up and put useable 4K video and frame rates with an efficient codec into a 7D, 5D, M6, and FF mirrorless. Then they could really call it a day.
I used the XC10 for an event I had to shoot and I actually really liked it. The biggest thing holding me back from buying one always was the fact that you couldn't interchange the lens. Putting an EF mount on this type of camera is exactly what I'm looking for so long as the price remains close to what it is today. Super excited about this!
